Old 7-Aug-2013, 9:56 AM   #13
SoTired
Thanks! I understand that's the conservative approach. As it happens, it's probably also the easiest approach to wire up. As long as the signal gets through, though, it's all good.
If the signal doesn't hold up, I suppose I can throw an amplifier into the system as well as the preamp.
SoTired is offline   Reply With Quote
