Old 7-Aug-2013, 2:42 AM   #3
nocable
The signals shown on this TV Fool report are strong... the gain of an 8-bay panel antenna is not needed & it would be a UHF only antenna. On the other hand, the ANT-751 is a very good fit with this TVFR. I would point it at about 140° (compass) and expect to see most if not all the local CA signals as well as many US signals.
OK I'll put the RCA antenna at 140 and report back.
But I'd really like to use the digiwave to see if I can't pick up some additional UHF stations. Can I put the RCA and the digiwave both on the same chimney? I don't have an official "mast" for the digiwave antenna. I plan on using a 6'x1.25" metal pole fastened to the chimney.
The digiwave antenna I bought has two separate panels that can be aimed in different directions. Each panel has its own coaxial cable and there's a small signal joiner to join the two cables. I was thinking I could aim the two panels in separate directions and instead of joining the signal at the antenna bring down two separate coaxial feeds into a simple switch. Then adjust each side separately. Would this work?
nocable is offline   Reply With Quote
