Old 6-Aug-2013, 2:09 AM   #2
Moderate and even long cable runs can be made reliable with the aid of a properly spec'd amplifier. For example, RG-6 cable should have less than 6 dB loss per 100'. that suggests that a preamplifier with 15 dB gain should be able to drive over 200' of RG-6 coax.
Reliable reception of weak / distant signals will generally be easier if the antenna is able to point at a clear horizon, free of obstructions such as vegetation, buildings and terrain. To 'chase down' the signals on azimuth 357° I would upgrade to an Antennas Direct 91XG combined with an Antennacraft Y10713 using the Antennas Direct EU385CF UHF/VHF Antenna Combiner. The Antennas Direct PA-18 preamp would be a good choice, capable of driving all the cable you've mentioned... With gain left over for splitter losses if needed.
So, yeah, I would look at a somewhat remote mounting if it provided a clear path along the antennas aim path.
You could consult with tinlee.com re. an antenna combiner that would allow you to drop the A/B switch. I'm thinking of the AC7 tuned for real channel 18 (WVTB).
