Old 6-Aug-2013, 2:19 AM   #3
The Tv / Tuning Device , Must Be Capable of Tuning the , ATSC , aka , 8VSB , Digital Broadcast Tv stations/channels.
A NTSC Analog tuner will Not tune the digital broadcast tv stations/channels.
Here are some converter boxes.
______________________
RCA DTA800B1 .
http://www.epvision.com .
http://www.channelmasterstore.com .
Or buy a New Tv.
Put the simple RCA 111 , rabbit ears antenna in/at a window that faces , South East or South.
The main group of Tv stations is to the , South East.
Aim the antenna at about 150 degree magnetic compass direction.
Here is how to aim indoor and out door antennas , http://www.kyes.com/antenna/pointing/pointing.html.
If the Tv is not in/at the window then run a Long coax from the antenna in/at the window to the Tv.
Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , Digital , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
________________________________
Is this a , house , town home , condo , apartment , mobile home , motor home , or etc??
What directions do the , windows , patios , balconies , face??
What floor??
What is the top floor??
Last edited by teleview; 10-Aug-2013 at 11:29 PM. Reason: Clarify information and typos.
