Old 5-Aug-2013, 3:53 PM   #4
bitscrambler
bitscrambler's Avatar
Send a message via Yahoo to bitscrambler
Hi guys, ok to start with , yes I've got my TV set to 'air'. I tried doing an autoscan for any channels - and got close to getting a couple -which maybe were the analogue channels I guess. I could see the pictures a bit but no sound at all. I used the fine tune option with these - still nothing.
Here's my updated signal analysis results. I used my address not that it changed much at all the terrian here is much the same.
And by saying 'hydro field' I mean a feild used for power transmission lines. They are at least 175feet tall, you can see from the pictures I've taken. We call electricity 'hydro' in Canada, which comes from the way some of ours is generated. I thought it would throw some people off but anyways. So my DB4 is facing directly into these power lines. Here are some pictures to clarify things.
From the pictures you can see what I mean I hope. There are two sets of power lines, actually. A set that feeds the houses , and another that I was referring to that may be my problem. Anyways, you people know more about this type of thing.
Thanks,
Jason
bitscrambler is offline   Reply With Quote
