Old 31-Oct-2010, 12:21 PM   #1
pulpfiction108
Any help is appreciated
Here is my TV Fool "plot" http://www.tvfool.com/?option=com_wr...81a32e7e78cdb6
I set up an Antennacraft HBU55 on a pole about 10 feet above roof line. No amplifier or rotator. Running through satellite coaxial. I do get 28 and 40 at 352 degrees as well as 31 at 73 degrees. I suppose this is a good capture considering the width of the reception (about 80 degrees. I do not have any fancy signal meters etc. Here is the problem I cannot get WESH 24 at 104 degrees. Too wide a path? As far as the antenna it does not seem to make a difference if I point either end due north or south I still get same signals. No visible difference in picture. Is there a front and back if so which is which? Any thoughts on pointing the antenna due east in an attempt to get 24 as well as the others? Odd thing the TVfool site indicates that for geen and yellow indoor should work, it did not for me. Maybe the metal roof was the cause.
Thanks.
YG
pulpfiction108 is offline   Reply With Quote
