Update: I installed the RCA ANT751 in the attic. I pointed at 307 degrees and received no channels. I did triple check the direction the antenna was to point. I assumed I just needed to go ahead and move outside, but before I did, I spun the antenna to the opposite direction and to my surprise, I received every channel. CBS is fairly weak but comes through 90% of the time. Sounds like I don't know how use a compass but I'm pretty confident I was reading it right. Just another thanks for the help, I'm enjoying high quality OTA tv now.
