Thread: Need Help
Old 4-Aug-2013, 3:29 PM   #8
Here is the Federal Antenna Law that says Yes you can install a Broadcast Tv Antenna of Any Size above the roof so as to have Reliable Reception.
http://www.fcc.gov/guides/over-air-r...n-devices-rule.
______________
The Tv reception is Very Weak Signal Strength at your location.
The current receivable channels at your location are all UHF channels , 14 thru 51.
Above the Peak of The Roof in such a manner that the roof and house are not impeding and blocking reception to the North West.
Recommend install a , Channel Master CM4228HD UHF antenna , aimed at about 309 degree magnetic compass direction.
______________
Install Winegard HDP-269 preamp.
______________
The Winegard DS3000 , J pole type antenna mount is a good mount for the CM4228HD antenna.
______________
______________
http://www.amazon.com.
____________________________________
Last edited by teleview; 4-Aug-2013 at 9:10 PM. Reason: Clarify information and typos.
