Old 4-Aug-2013, 8:24 AM   #5
SoTired
Originally Posted by Stereocraig View Post
Mounting to the chimney, will subject the antenna and it's connections to heat/ cool cycles, moisture and/ or creosote, birds perching on the elements and stress on the mortar joints.
Thanks, guys!
On the chimney issue, given that we do not ever use the fireplace, how will it subject the antenna to heat/cool cycles, moisture, and creosote? I'm not quite following.
As for birds perching, will they not perch on the antenna unless it is mounted to a chimney? Sorry if these are stupid questions, but this is all new to me.
I understand the stress on the mortar joints, but the others were a bit confusing.
SoTired is offline   Reply With Quote
