Old 3-Aug-2013, 5:03 PM   #3
rcoop
Thank you! We can go a little higher up to 30 feet. Here is the signal analysis for that height. Does it help? I get two more green stations, but they are at 117° and 122° so that is a different direction than my antenna would be pointed.
http://www.tvfool.com/?option=com_wr...46aeeebaf4bc9c
331 degrees actually points away from the maple. We have a few pine trees 70 feet away that might interfere, but they are about 30-40 ft tall and a little to the left of the direct point.
So my next questions are will the maple that is on the backside interfere with the antenna? Or do we only have to worry about the trees in front of the antenna that are 70 feet away? Can we tilt the antenna upward slightly to clear them?
Also, while I will be happy with just Baltimore, I would love to try to get a few D.C. Will the Winegard get a few? I rather have the Baltimore clear then both without the clearest reception.
Also, I forgot to mention that my house is a brick house from the 70's on slab. Rewiring it is virtually impossible. Currently Direct TV and Atlantic Broadband have different access points in our house for their cable/ satellite. We were just planning to hook up from the outside into one of their old feeds. On the run are 3 TVs. The ones that I really care about are 30 ft apart. The other Tv is in our bedroom and another 30 feet away.
rcoop is offline   Reply With Quote
