Old 2-Aug-2013, 10:44 PM   #11
Is there a bit of wind moving the trees today... more than yesterday? When aiming through trees, wind causes poor reception by creating fluctuating signal at the antenna. The symptoms would be as you describe.
As you disconnect and reconnect cables, it's possible that the contacts inside one or more connectors has spread and is no longer making reliable contact
