Old 2-Aug-2013, 9:20 PM   #8
Daddylion
Originally Posted by No static at all View Post
Upon closer examination, the FM trap & combined settings are the default from the factory, but you can double check them to make sure.
The fact that channel 7 completely disappears makes me lean towards FM 91.3 being the culprit. You won't know till you try adding the RS FM trap before the amp input. You can return the trap to Radio Shack if it doesn't help.
The FM filter didn't seem to help, and now every channel wildly fluctuates. Channels that were stable yesterday now drop out completely for a few seconds and then come back. I will have 70 or 80 one second and 0 the next. This continued after I removed the FM filter and the preamp.
Daddylion is offline   Reply With Quote
