Old 2-Aug-2013, 12:10 PM   #7
No static at all
No static at all's Avatar
Upon closer examination, the FM trap & combined settings are the default from the factory, but you can double check them to make sure.
The fact that channel 7 completely disappears makes me lean towards FM 91.3 being the culprit. You won't know till you try adding the RS FM trap before the amp input. You can return the trap to Radio Shack if it doesn't help.
