Is the pre-amp set to combine? Is the FM trap in the on position?
I would also try installing a Radio Shack FM trap between the amp & antenna. You have a 250 watt FM station right in town (91.3). The internal trap of that amp does not effectively attenuate FM stations below 95Mhz.
