Old 1-Aug-2013, 8:11 PM   #14
mulliganman
Thought I'd follow up with my final results. Fox KRBK was a no go with the Clearstream2V with the preamp. Other stations were pulled in fine. Was able to pull in the KRBK pointing a directional antenna toward Branson and the KWBM (which is sharing an antenna with KRBK). The signal strength was in the mid to low forties though. Changed the directional antenna to point towards Bolivar and the picked up KRBK Fox with a signal strength in the seventies.
Thanks for all the suggestions and input.
mulliganman is offline   Reply With Quote
