Have you tried running with no preamplifier? (All parts of it removed from the system.)
If you have already tried moving the ANT-751 to all possible locations, you may need to consider going up to a larger, higher gain antenna.
Given that you are forced to aim though vegetation, a Winegard HD7694P or Antennacraft HBU-33 would not be overkill... even the larger versions of those designs would be worth considering.
