Old 1-Aug-2013, 12:09 AM   #5
Originally Posted by tuktuk View Post
Thanks so much for the help. Follow up, do I need pre-amp with either the C2V or the HD1080?
thanks,
M
If driving only one TV and with 50' or less coax, no.
If you are driving a long run of coax and an 8-way splitter... maybe.
I would try this 'barefoot', you can always add an amplifier if the need is proven... That is, you have good reception at the antenna but the added loss caused by cable and splitting causes the loss of one or more signals.
