Old 31-Jul-2013, 11:47 PM   #3
For reception to the , North West , North , North East , East , South East.
With 1 antenna.
Install a Channel Master CM5016 All Channel antenna.
All channel antennas are desinged to receive all the channels.
UHF band channels 14 thru 51.
_________
Aim the CM5016 antenna at about 300 degree magnetic compass direction.
With the CM5016 antenna aimed at about 300 degree magnetic compass direction the Tv stations in the different directions will be received.
Will be received Without a antenna rotator.
Will be received Without a second antenna.
______________
A antenna system amplifier is Not required.
______________
A Winegard DS3000 , J pole type antenna mount can be used with the CM5016 antenna.
_________
http://www.solidsignal.com.
http://www.amazon.com.
http://www.channelmasterstore.com.
Last edited by teleview; 2-Aug-2013 at 8:50 PM. Reason: Clarify information and typos.
