Old 31-Jul-2013, 9:58 PM   #7
You have something that you can share with someone else. Just pass it on...
A premium grade rotator would be the Hy-Gain AR-40. http://www.hy-gain.com/Product.php?productid=AR-40
If that's too pricey, then consider the CM-9521A or NTE U-105 or U-106. If you use the Channel Master or NTE type rotator I would strongly suggest adding a TB-105 thrust bearing to the install.
http://www.3starinc.com/tb-105_thrus...a_rotator.html
http://www.3starinc.com/nte_u-106_an...ontroller.html
http://www.channelmaster.com/Best_An...9521A_s/63.htm
