The signal from WIWN on real CH-5 calls for an all channel antenna such as:
Winegard HD7084P
Channel Master CM3018
Antennacraft C490
Consider the following preamplifiers:
Winegard HDP-269
Antennacraft 10G201
Channel Master CM-7778
If the splitter must be located between the preamplifier (outside at the antenna) and the the preamp power supply (inside, protected from the elements), Antennas Direct offers splitters that pass power. http://www.antennasdirect.com/store/splitters.html If you don't need the power passing feature, Ideal brand splitters at Home Depot or Amazon will serve well.
Reason: power passing splitters
