Thread: Ixonia, WI
Old 31-Jul-2013, 8:40 PM   #1
schmeckp
Ixonia, WI
Hi,
Looking to determine the best antenna to receive the top 12 stations from my tvfool report (94 degrees, 35 miles), and what setup you would recommend to split the signal to 4 TVs throughout the house.
The antenna will be roof mounted, about 20 ft above ground level (can go as high as 24 if needed. The cable runs vary from 35ft to 80ft in length, and they will be to 4 separate TVs. From the antenna, each tv is 35ft, 45ft, 60ft and 80ft (cable length) respectively.
20ft up:
http://www.tvfool.com/?option=com_wr...46ae480f8f06b0
24ft up:
http://www.tvfool.com/?option=com_wr...46ae4395e75f19
Appreciate opinions on antennas and splitter / amp setup.
schmeckp is offline   Reply With Quote
