Old 31-Jul-2013, 6:03 PM   #2
Can you mount the existing antenna higher?
Have you run reception reports for higher elevations? When I click on the call sign of the WPBY entry of your reception report, the path profile suggests that you may not be able to get LOS (line of sight) without going up quite far... but it's still worth checking.
How many TV's are you going to feed from this antenna?
