Old 31-Jul-2013, 4:39 AM   #8
l37
If considering a 4-bay, My experience with the Antennas Direct DB4e has been quite positive. It beats the older competing designs which were engineered to cover channels no longer used for OTA TV broadcasting. By engineering the DB4e to focus on real channels 14 through 51, AD was able to squeeze some additional gain out of the antenna.
That said, if you already own a CM-4221 or other 4-bay... give it a try.
Should I use an amplifier with the DB4e?
l37 is offline   Reply With Quote
