Old 30-Jul-2013, 11:03 AM   #1
OTACanuck
Connecting Two 4228HD Antennas to Boost Signal Strength in Same Direction
For the last two years we have been running a 4228HD antenna attached to a CM-7777 amplifier using a 3ft pieces of coaxial cable. This setup has been great and is used on a daily basis without problem.
We recently acquired a second 4228HD antenna and we are hoping to combine the two antennas to boost signal strength from the same direction. I have mounted the new 4228HD antenna directly above the existing antenna (on the same pole). The bottom of the new antenna is spaced 4" above the top of the old antenna. Both antennas point in the exact same direction. Both antennas are connected to output sides of a 2-port digital splitter from PCT (not sure of the model number, but I think it is an indoor version) using 3ft pieces of coaxial cable. Another piece of 3ft coaxial cable connects the 2-port splitter (the input side) to the CM-7777 amplifier. From that point to the TV the setup remains unchanged.
Now with the new setup described above we don't receive any channels when we used to get 20+ channels with the old setup. Can you tell me if I have done anything wrong? Do I need to use a special splitter to combine the signals from the two antennas? Any help would be greatly appreciated.
OTACanuck is offline   Reply With Quote
