30-Jul-2013, 6:06 AM
#5
I am concerned that all of your signals are listed as 1-Edge & 2-Edge. This typically means that at your location they are being blocked. In your case probably by hills or mountains. The signals will “bend” or diffract to some degree around these obstructions but based on my experience in Moreno Valley, CA you can’t depend on “Edge” reception 100% of the time. Here is my TV Fool report:
http://www.tvfool.com/?option=com_wr...1dda169109ca5c
While I get channel 11 & 13 most of the time, there are times I can’t get one or both at all. The same applies to all of the channels below them in my TV Fool report. In other words, your reception will at times be at the mercy of existing propagation conditions.
I use an Antennas Direct 91XG for UHF and an Antenna Craft Y10 7-13 for high VHF with a +15 dB amplifier increasing the signal from both antennas before the amplifiers outputs are combined in a UVSJ.
http://www.solidsignal.com/pview.asp...u=853748001910
http://www.solidsignal.com/pview.asp...u=716079000994
