I expect you already know this but just in case I’ll mention it. CBS Channel 8 (8.1) and ABC channel 10 (10.1) are High VHF channels that come from La Jolla @ 202 deg. FOX, PBS & NBC are UHF channels @ ~165 deg. Because of the 37 deg. separation, you might consider using two antennas, one for High VHF aimed 202 deg. and a UHF antenna aimed ~165 deg. You would combine them through a UHF/VHF Signal Joiner (UVSJ). The two separate antennas would be shorter than a single combined antenna and could be aimed to their respective stations without a rotor.
