Old 28-Jul-2013, 3:55 AM   #5
Billiam
A 4221 pointed at all those stations at 50 degrees should obtain every signal in Yellow plus the one in Green since it is fairly strong even if you are off axis with your placement. A pre amp should help too. I used one in a similar situation. One station on CH. 19 in green and the rest in yellow and red. Worked fine even with much larger antennas.
