Distant Tv signals and distant Tv signals crossing mountatins and etc. tend to shift and move , up and down / side to side.
The Big Broad Flat Surface of the CM4228HD UHF Antenna receives signal as the signal moves and shifts.
The CM4228HD is a stacked antenna both vertical and horizontal.
_________________________
The Tv signals scatter and bent as the Tv signals come across the mountains.
This creates hot spots and cool spots signal strengths.
Can help to move the antenna around , higher and lower , left and right , forward and back , probing , searching for a good hot spot location.
Reason: Clarify information and typos.
