Thread: Behind Hill
Old 26-Jul-2013, 5:17 PM   #3
The Channel Master CM-700PAL, CM-7001 and CM-7400 come to mind: http://www.channelmasterstore.com/Se...Boxes_s/27.htm
Remember, an amplifier is not going to 'pull' any more signal from the antenna or air... it can only 'push' the signal though the cable and splitter losses that are connected to the output side of the amplifier. This means you may need to consider other mounting options, higher is often the direction to go.
