I don't know what the specifics of the 5891 or the NF-470's notch (the diagram isn't accurate enough). I'm not optimistic it will work well enough without causing collateral damage.
Do not get the 4228 instead of the 91XG, it is not going to solve this problem. Neither will an HDP-269.
When I tested the CM-3414 I only ran a few feet of RG6 cable to the temporary TV setup trying to prevent low signal.
Placing an amplifier at the TV does very little in most cases. Place the amp at the antenna for best results.
