Old 25-Jul-2013, 6:13 PM   #5
The Best Action now is to Test Reception by putting the antenna on the roof , lay the antenna on top of a chimney , or put a Non metal chair on the peak of the roof two legs on one side and two legs on the other side of the peak of the roof and lay the antenna on the chair or some other way to get the antenna up high.
Top Rail Fence Pipe Sections are long , and make a good way to get the antenna up high for the Test reception.
Top Rail Fence Pipe Sections can put together to make a long pipe to get the antenna up higher for a Test of reception.
The top rail fence pipe can have one end on/in the ground , the top rail fence pipe will stand straight up can be strap to the eave of the house up high , the top rail fence pipe will extend straight on up and the antenna will be mounted on the top end of the top rail fence pipe.
This top rail fence pipe installation can be temporary for Test reception or a permanate installation.
Here are some antenna mounts that do not make holes in the roof.
Measure the chimney and use a , ronard (2212) , ronard (2218) , ronard (2224) .
Use the , ronard #4560 eave antenna mount.
Buy the ronard antenna mounts at http://www.solidsignal.com , by typing , ronard (x) , in the solidsignal search box or buy from http://www.ronard.com.
______________
