Old 24-Jul-2013, 5:15 PM   #3
Based on the provided tvfool report that is resolved to block level only and is at the default 10 feet antenna height above ground.
The Local Tv Digital Broadcast stations/channels in the Green reception zone of the tvfool report are strong signal strength.
_______
As to the pole height for the antenna.
As always , the Best Practice is to install a Tv antenna at a height that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house and roof and other obstructions that are in the the way of reception.
For reception of the Local Tv stations/channels the directions are , North West , North , North East , East.
About 25 feet pole height should be Ok.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv reception with a Tv antenna.
Multi-path/reflections. Absorbing. Blocking. Tv reception.
The Best Practice is to install a Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
_______
Install a Antenna Craft HD850 antenna and aim the HD850 antenna at about 27 degree magnetic compass direction.
_______
Install a Winegard , LNA-100 'Boost' , antenna system amplifier.
_______
For 1 tv connected use No splitter.
For 3 Tv's connected use a simple common 3 way splitter.
_______
http://www.solidsignal.com.
http://www.amazon.com.
_______
http://www.3starinc.com.
Has push up poles.
__________________________________
Many people are receiving Tv ~via~ a Tv antenna.
And also are receiving , Streaming internet services , such as , Netfix and Hulu+, that are very low monthly cost.
The Internet box that is easy to use and has flexibilty of use , that I recommend to receive the Streaming internet services is , http://www.roku.com.
