Old 24-Jul-2013, 2:38 AM   #2
A Simple reception situation.
For reception of the Local Digital Broadcast Tv stations/channels in the Green reception zone of the tvfool report.
Install a Channel Master CM4220HD antenna above the roof in such a manner that reception is not impeded and blocked by the roof and house in the directions of , East , South East , South.
Aim the CM4220HD antenna at about 150 degree magnetic compass direction.
___________________________________
No antenna system amplifier is required.
For 4 Tv's connected use a simple common 4 way splitter.
http://www.solidsignal.com.
http://www.amazon.com.
Disconnect and Remove satellite system passive and active devices such as and not limited to , multi-switches , multi-plexers , splitters , combiners , amplifiers , power injectors , power supplies , and etc. .
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Scan for channels.
____________________________________________
Last edited by teleview; 24-Jul-2013 at 4:15 AM. Reason: Clarify information and typos.
