Old 24-Jul-2013, 12:22 AM   #3
The reception signal strengths are Very Strong Signal Strengths.
The 2 Main Groups of Tv stations are to the , North East and South East.
Do Not use any type or kind of amplified antenna.
Zip , Zero , Zilch , Non.
A Terk HDTVi is a Non Amplified Antenna.
Aim the HDTVi antenna at about 60 degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
__________________________________________
As a first choice.
Place the TERK HDTVi in/at a East facing window and run a coax to the Tv.
A glass patio/balcony door is also a window.
Can also place HDTVi antenna in/at , North East or South East facing window.
It is best not have any close buildings or big trees to the , North East , East , South East , because obstructs reception.
What is the building construction??
Wood Frame with wood or vinyl siding has the least amount of obstruction to reception.
The following is a Not Complete list of building construction that Will Disrupt and Obstruct Reception More.
Concrete , concrete blocks , bricks , rocks , metal siding , metal roof , metal beams , metal doors , metal backed insulation , stucko Wire .
The inside of buildings and attics Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Reasons:
Multi-path/reflections signals bouncing all around.
Absorbing reception.
Blocking reception.
Last edited by teleview; 25-Jul-2013 at 12:24 AM. Reason: Clarify information and typos.
