Old 23-Jul-2013, 9:34 AM   #2
A Simple reception situation.
Stucko ->Wire<- impedes and blocks Tv reception.
Concrete roof tiles do reduce reception.
If have a choice , I recommend aim the antenna through the concrete roof tiles.
Start with a Antenna Craft HBU33 antenna in the attic aimed at about 200 degree magnetic compass direction.
Install a Winegard , LNA-100 'Boost' , antenna system amplifier.
Most newer houses have a electrical outlet in the attic to plug the LNA-100 amplifier into.
If reception situation/problems happen in the attic and are not resolvable by adjusting antenna aim and locations in the attic.
Then install the HBU33 above the roof in such a manner that reception is not impeded and blocked by the roof and house in the directions of , South West , South east.
Here is a antenna mount that installs on the eave.
http://www.ronard.com/34424560.html. Use the , ronard(4560) .
Buy the ronard antenna mount at solidsignal by typing , ronard (4560) in the solidsignal search box or buy from ronard.
Or can also use a Winegard DS3000 J type antenna mount.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.ronard.com.
_____________
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Scan for channels.
_________________
With antenna installed above the roof , Test reception , with and without the LNA-100.
______________________________________
