Old 22-Jul-2013, 9:19 PM   #3
A Simple reception situation.
For reception of the Digital Broadcast Tv stations/channels install a ANT751 antenna above the roof in such a manner that the roof and house are not impeding and blocking reception in the directions of , North East , North , North West , West , South West.
Aim the ANT751 antenna at about 350 degree magnetic compass direction.
______________
Can also use the DB4e above the roof.
_______
Install a Winegard , LNA-100 'Boost' , antenna system amplifier.
_______
For 3 Tv's connected use a simple common 3 way splitter.
____________
For reception of the Digital Broadcast Tv stations/channels the Tv Must Channel scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu.
___________________________________________________________
As for the cable tv system Leakage.
Can use a ANT751 antenna as a hand held probe.
Connect a Real Long Coax to the ANT751 antenna.
Or can use a Portable Battery Operated Digital Tv and ANT751.
Go probing looking for where the cable tv signal is the strongest.
Home Depot and Lowes will sometimes have the ANT751 antenna in the store , no matter what the Home Depot and Lowes web sites say.
http://www.solidsignal.com.
http://www.amazon.com.
Last edited by teleview; 24-Jul-2013 at 6:39 PM. Reason: Clarify information and typos.
