					Originally Posted by  teleview
				If the tivo's will accept 2 Tv antennas / inputs on the tivo's /  Do the tivo's have 2 tuners in the tivo's ??
Run a separate coaxes for the antennas.
 Nope. TiVos have two tuners, but only one coax tuner input.
 This looks promising if there's no channel-specific Jointenna available...
Another way to do it is , run coaxes from each antenna to the Tv / Tivo locations and use remote control A/B antenna switches.
 http://www.mcmelectronics.com. #32-4425
 Won't work -- the TiVo can't be programmed to flip an A/B switch prior to initiating a recording.
Thanks for your suggestions!
