Old 22-Jul-2013, 5:08 PM   #8
elmo
Originally Posted by dom.ruiz View Post
The Leaf can pull in VHF and UHF. Your location is so fantastic that you should have no problem pulling in all the green channels on your TV Fool. You're less than 10 miles away, and you have a clear line of sight. Get the Leaf and don't look back.
Well, by design, the bow tie is for UHF reception. The Leaf has two bow ties (similar to an Eagle Aspen dtv2buhf, minus the reflector). Sure, put it near a strong VHF signal and it will pick it up, but not as well as a VHF design will. I'd never suggest anyone attempt to tune a signal without the correct antenna. Spending time and money on the wrong tool is a waste, IMO. Getting the best signal strength means you get the best reception, even in adverse conditions.
If OP gets the Leaf, maybe he can post back with results, specifically signal strength for Ch 3.
