Old 21-Jul-2013, 11:03 PM   #2
You are maxed out with the home made antennas.
Time to move up.
The Current Broadcast Tv stations/channels in , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has channels in all three channel bands.
Most of the signal strengths at your location are Weak Signal Strength.
Concerning WMC-DT Real channel 5 NBC is , low signal strength , 2 edge path obstruction , and 66.2 miles away to the South West.
Low band channels are effected more by interference.
I can not say reception will be reliable even with a Big antenna.
Time for a BIG All Channel Antenna.
Above The Peak of the Roof in such a manner that reception is not impeded and blocked by the roof and house in the directions of , South West , South , South East.
Install a Winegard HD7084P All Channel antenna aimed at about 207 degree magnetic compass direction.
_____________________________________
Install a Winegard HDP-269 preamp.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.ronard.com.
Here are some strong and sturdy antenna mounts.
Use the 5 foot tripod antenna mount , ronard(911) .
Use the , ronard(4560) eave antenna mount.
Measure the chimney and use a.
ronard(2212) , ronard(2218) , ronard(2224) , chimney antenna mount.
Buy the ronard antenna mounts at solidsignal or buy from ronard.
______________________________________
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on broadcast Tv reception and so do buildings including your own roof and house and other obstructions.
The Best Practice is to install the HD7084P antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Digital Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do Double Rescan , http://www.dtv.gov/rescan.html.
Many Digital Tv stations/channels will be received.
The Only Way to Know how many Tv stations/channels are received reliably is put the Big HD7084P antenna up high and see what happens.
