Old 19-Jul-2013, 5:29 PM   #3
Please note that I updated a typo that was HBU33 antenna and is now Y5713 antenna.
(If you have ordered the HBU33 antenna , Yes it will work Ok.)
__________
Please note that this is really a simple installation when done one step at a time.
Reason: The wheel is not being reinvented.
Install the antenna mount , then the antennas , aim the antennas , make the connections to the combiner and etc. .
_______________
The reason I have recommend this set up is because , receives Tv stations both directions , West and East.
If I recommend 1 antenna to receive either West or East.
Then down the road , when you become more aware of what is being received and not received.
And yes you will become more aware.
You will most likely return and - Say , what about some Tv stations in the other direction.
___________
Yes this does look like a lot , however it is jumping through the least amount of hoops.
_________________________________
Last edited by teleview; 20-Jul-2013 at 9:19 PM. Reason: Clarify information and typos.
