Old 19-Jul-2013, 4:44 PM   #4
Antenna mileage numbers are a general guide.
If a antenna says 45 miles that does not mean that the antenna stops receiving at 45 miles.
As to elevations up or down.
If the elevation is up or down and is LOS=Line Of Sight then up or down is Ok.
If there are land obstructions , hills/mountains in between or other obstructions then the obstructions will effect reception.
The tvfool report shows one edge path obstruction.
The CM2016 should receive OK , the important situation is to install the CM2016 at a location that has the least amount to no amount of Close obstructions that will reduce reception.
