Old 18-Jul-2013, 11:17 PM   #2
The Current Plus Pending Applications Included Radar Map Plot shows the -->Main Group<-- of Broadcast Tv stations/channels is to the -->West<--.
1 Tv station to the , North West.
1 Tv station to the , North East.
1 Tv station to the , East.
1 Tv station to the , South.
Installing the CS2v antenna on the , North side of the house is not a good place.
The Best Practice is to install a Tv reception antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Install the CS2v antenna Above The Peak Of The Roof in such a manner that the roof and house Are Not impeding and blocking reception in the directions of , West , North West , North East , East , South.
Aim the CS2v antenna at about 255 degree magnetic compass direction.
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on broadcast Tv reception and so do buildings including your own roof and house and other obstructions.
The Best Practice is to install a Tv reception antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
____________________________
For reception of the Digital Tv stations/channels in the tvfool Current Plus Pending Applications Included radar map plot and channel list.
In the Green and Yellow reception zone of the tvfool report , a antenna system amplifier will most likely not be required.
______________________________
Last edited by teleview; 19-Jul-2013 at 5:06 AM. Reason: Clarify information and typos.
