Old 18-Jul-2013, 10:48 AM   #2
Yes the CM7777 has 30dB of gain and that is to much.
A CM7778 has 16 dB of gain and that is better.
However the Winegard HDP-269 preamp has 12dB of gain and is also designed to resist overload.
_______________________________________
Yes all parts of the amplifier can be installed before the splitter , the preamp , power injector , power supply.
It the power supply and power injector is after the splitter , then one or more of the outputs of the splitter needs to be 'power passing' through the output to the input so the preamp unit can receive power.
The , power supply , power injector , preamp , is connected to a power passing port.
The preamp can not operate without power.
________________
Attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Multi-path/reflections signals bouncing all around can be too many signals for the tuners computer to correct.
And attics and inside of buildings , absorb and block Tv reception.
________________
To improve reception and happiness.
Install the HBU33 antenna above the roof in such a manner that the roof and house are not blocking reception to the , North East and West North.
Most likely , a HDP-269 preamplifier will not be required with antenna above the roof.
Last edited by teleview; 18-Jul-2013 at 5:17 PM. Reason: Clarify information and typos.
