The signal strengths of the Tv stations are weak signal strength , The tvfool report has a antenna height of 12 feet above ground.
Do not delete the tvfool report with antenna height of 12 feet above ground.
_______
To see what signal strengths are at higher antenna heights.
Make and post 3 more tvfool reports with antenna heights at , 25 feet , 40 feet , 60 feet.
