Old 16-Jul-2013, 8:02 PM   #2
Above the Peak Of The Roof in such a manner that the roof and house are not impeding and blocking reception the directions of , North West , West , South West , South , South East.
Install a ANT751 antenna aimed at about 309 degree magnetic compass direction.
_______________________________________
No antenna system amplifier is required.
Expect to receive the Digital Broadcast Tv stations/channels listed , Current Plus Pending Applications Included Digital channels list in the Green and Yellow reception zones.
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on , broadcast Tv reception with a Tv antenna and so do buildings and other obstructions including your own roof and house and other obstructions.
The Best Practice is to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house and other obstructions.
The Tv/s Must Chanel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 16-Jul-2013 at 11:33 PM. Reason: Clarify information and typos.
