Old 16-Jul-2013, 11:23 AM   #25
toadcat
I guess it doesn't hurt to add the image.
So these FM signals will only interfere with the VHF antenna if/when I decide to add it and point towards Topeka. Which should be the stations in the 280deg to 310deg direction.
Just another clarification to see if I have this right. After I attach the antenna, I then add a grounding block to run the rg6 through before it gets into the house. From what I have read, this ground wire should run to my ground rod at my service entrance. If so, this is a pretty long distance and will have at least two bends. Is it recommended to add another ground rod at the shortest distance and straight line to the antenna/mast? Then I connect that ground rod to my ground rod at the service entrance. I am calling the service entrance where my meter sits on a pedestal. I attached a rough drawing of it all. Blue lines are the ground wires.
Well I bought the Clearstream4 and a J mount and they should be here Friday or Monday. I shouldn't need a amplifier so I am going to set it up and see what happens.
Thanks!
toadcat is offline   Reply With Quote
