Thread: Antenna Advice
Old 16-Jul-2013, 1:40 AM   #4
Above the Peak of the Roof in such a manner the roof and house are not impeding and blocking reception to the , East North and East.
Install a Antenna Craft , HD850 antenna aimed at about 82 degree magnetic compass direction.
_________________________________________________
There is a Digital Broadcast Tv station to the , South , at 176 degree magnetic compass direction.
That has 5 Digital Tv channels , RTV , PBJ , My Family , Tuff Tv , Frost Great Outdoors.
To receive WRTD-LD Real UHF channel 46 , http://en.wikipedia.org/wiki/Luken_Communications , will require a second antenna.
Install a Channel Master CM4228HD Antenna aimed at about 176 degree magnetic compass direction.
Use a Winegard CC7870 transformer coupled (hybrid) antenna combiner to connect the , HD850 and CM4228HD together on to one coax down lead.
Make the coax from each antenna the same length between the antenna and the combiner.
Separate the HD850 and CM4228HD by about 2 feet or so on the same mast pipe.
The CM4228HD on top and HD850 on bottom.
____________
Connect a Winegard HDP-269 preamp to the output of the CC7870 combiner.
____________
Buy the HFS splitters at , http://www.solidsignal.com.
____________
http://www.amazon.com.
____________
