Old 16-Jul-2013, 12:08 AM   #2
A Simple reception situation.
Above the Peak of the Roof in such a manner that reception is not being impeded and blocked by the roof and house in the directions of , East and West.
Install 2 antennas.
Aim a Antennas Direct , Clear Stream 4 UHF antenna at about 82 degree magnetic compass direction.
Aim a Antenna Craft , Y5713 VHF high band antenna at about 272 degree magnetic compass direction.
Install the CS4 on top and the Y5713 on the bottom on the same mast pipe.
Separate the 2 antennas by about 2 feet or so.
Use a Antennas Direct , EU385CF-1s , diplexer/combiner to connect the CS4 and Y5713 together.
Connect the CS4 to the UHF connection of the combiner.
Connect the Y5713 to the VHF connection of the combiner.
The remaining connection of the combiner is connected to a Winegard AP8700 preamplifier.
___________
Use the 5 foot tripod antenna mount. ronard (911) .
Use the , ronard (4560) , eave antenna mount .
Measure the chimney and select. ronard (2212) , ronard (2218) , ronard (2224) .
Buy the ronard antenna mounts at solidsignal by typing , ronard (x) , in the solidsignal search box or buy from ronard.
Buy the HFS splitter at , http://www.solidsignal.com or buy from ronard.
Here are some places to to buy antennas and etc. .
http://www.solidsignal.com.
http://www.amazon.com.
http://www.ronard.com.
http://www.antennacraft.net.
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on reception , multi-path/reflections , absorbing , blocking , reception , and so do buildings including your own roof and house and other obstructions.
The Best Practice is to install the antennas at a location that has the least amount to no amount of obstructions in the directions of reception , at your location that is , East and West.
The Tv'/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or ' Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
____________________________
Last edited by teleview; 19-Jul-2013 at 4:59 PM. Reason: Clarify information and typos.
