Old 13-Jul-2013, 10:16 AM   #2
Above the roof in such a manner that the roof and house are not blocking reception to the , North East , East , South East.
Install the AntennasDirect , ClearStream 2V-J3.
Aim the CS2v antenna at about 80 degree magnetic compass direction.
______________
Install a Channel Master CM3418 , 8 way distribution amplifier.
Here is an example of a CM3418. http://www.amazon.com/Channel-Master.../dp/B002M1EPL0.
Terminate any unused output ports of the distribution amplifier.
Here is a example of 75 ohm terminators. http://www.amazon.com/Type-75-Ohm-Te.../dp/B000AAN76Y.
_________________________
The coaxes that are in/on the house can be used for the antenna/distribution system.
Active cable system coax , cable tv service , cable internet service , cable phone service , must be on a Separate coax that is not part of the coaxes are used for antenna system coaxes.
Some satellite systems have provisions to distribute Tv antenna signals via the active satellite system coaxes and some satellite systems do not.
If the satellite system is not active , then Disconnect and Remove All componets such as and not limited to , multi-swithes , multi-plexers , combiners , splitters , amplifiers , power injectors , power supplies , and etc. .
Yes the satellite system coaxes can be used for the antenna system if the satellite system is not active.
_____________________________________________________________________________
As a test to see what is received , I recommend connect a continues length of coax from the CS2v antenna and run the continues length of coax through a open window or door direct to 1 Tv.
No amplifiers , no splitters , grounding couplers , no etc.
_______
Using google and yahoo to search what programing is on the Tv stations/channels are.
These Broadcast Tv stations/channels should be received.
KETK-TV , NBC and Estrella Tv .
http://en.wikipedia.org/wiki/KETK-TV.
KLTV-DT , ABC and Telemundo .
http://en.wikipedia.org/wiki/KLTV-TV.
KTPN-LP , MyNetwork and FOX .
http://en.wikipedia.org/wiki/KTPN-LP.
KFXK-DT , FOX and MyNetwork .
http://en.wikipedia.org/wiki/KFXK-TV.
_______________
http://www.rabbitears.info/market.ph...callsign=55643.
K25GL-D , Religion .
KCEB , Me-Tv and Mundo Fox .
KYTX-DT , CBS and CW+ and Cozi Tv.
__
K20DL , Trinity Broadcasting Network . May or may not be transmitting and may be a Analog or Digital Tv station.
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on Broadcast Tv reception and so do buildings including your own house and other obstructions.
The Best Practice is to install Tv antenna at a location that has the least amount to no amount of obstruction of any type or kind in the directions of reception.
The Tv Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
_________________
http://www.solidsignal.com.
http://www.amazon.com.
Last edited by teleview; 14-Jul-2013 at 3:40 AM. Reason: Clarify information and typos.
