The HD850 antenna has Wide forward beam width , Wide forward angle of reception.
That is why I recommend the medium size HD850 antenna.
And the 2 Digital Tv stations to the , west south , west north.
WTTO-TV Channel 10 Religion.
WSPY-CD UHF channel 35 America One.
Are medium strong signal strength and will most likely be received by the HD850 Antenna through the back/back angle of the HD850.
No antenna rotator is required and No second antenna is required.
Install the HD850.
-->If<-- notice the word If does not say , will be.
-->If<-- a second antenna is required then a second antenna can be installed at a later date.
It is important to get the HD850 up and receiving.
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a signal strength meter and some Digital Tv's also have a signal quality meter.
Reason: Clarify information and typos.
